Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Lukaboii88
Dec 04, 2018Aspirant
Could I please get the hot fix firmware too ? Thank you in advance.
- Netduma_JackDec 04, 2018NetDuma Partner
No problem - I will PM you all now.
- M-HafeezDec 04, 2018Tutor
Thank you dear, I will upload it and test it thoroughly then will provide you all some feedback. by the way, I have recently updated the router as it said update available. I updated it and its performing good than before but the wired connection is still having trouble. let's see this firmware will work or not. Thanks for your continuous support guys.
Thanks for the update and the kind words! Hope it continues to perform well for you.
- T-Morgan-911Dec 04, 2018Aspirant
It was longer between drops but I am still experiencing drops after the hot fix.
- B1ggSh00t3rDec 04, 2018ApprenticeI’m willing to give the “hotfix” a try. Please send me the link when you have time.
