Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Lukaboii88
Dec 04, 2018Aspirant
Could I please get the hot fix firmware too ? Thank you in advance.
Netduma_Jack
Dec 04, 2018NetDuma Partner
No problem - I will PM you all now.
- M-HafeezDec 04, 2018Tutor
Thank you dear, I will upload it and test it thoroughly then will provide you all some feedback. by the way, I have recently updated the router as it said update available. I updated it and its performing good than before but the wired connection is still having trouble. let's see this firmware will work or not. Thanks for your continuous support guys.
- Netduma_JackDec 04, 2018NetDuma Partner
Thanks for the update and the kind words! Hope it continues to perform well for you.
- T-Morgan-911Dec 04, 2018Aspirant
It was longer between drops but I am still experiencing drops after the hot fix.
- B1ggSh00t3rDec 04, 2018ApprenticeI’m willing to give the “hotfix” a try. Please send me the link when you have time.
- Netduma-FraserDec 04, 2018NetDuma PartnerMorgan have you tried previous workarounds - consoles not Instant On mode/using a Switch to see if thats also the issue for you?
B1gg sent you PM, not sure if you have already
