Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma_Jack
Dec 04, 2018NetDuma Partner
No problem - I will PM you all now.
M-Hafeez
Dec 04, 2018Tutor
Thank you dear, I will upload it and test it thoroughly then will provide you all some feedback. by the way, I have recently updated the router as it said update available. I updated it and its performing good than before but the wired connection is still having trouble. let's see this firmware will work or not. Thanks for your continuous support guys.
- Netduma_JackDec 04, 2018NetDuma Partner
Thanks for the update and the kind words! Hope it continues to perform well for you.
