Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
rickvidallon
Dec 21, 2018Aspirant
I went out and bought a x10. I figured if I throew more money at the problem it might help.
Got home and could not connect LAN or WAN. Nothing.... Crap, crap, crap. After 3 hours I found an old post where someone had did the following.
1. Reset the router. (paper clip in slot)
2. Reboot router
3. Under security turned-off one bandwidth for WPA (takes a while.. go grab a beer)
4. Reboot again
5. Everything connected.
6. Restore WPA security.
7. LAN and WAN working now ( more shall be revealed; fingers crossed)
