Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Jan 17, 2019NetDuma Partner
We identified that devices mainly consoles in a standby state can cause the internet to disconnect. We're investigating it, make sure to turn off the console fully and that should resolve it
kscott76
Jan 17, 2019Initiate
I will try that. My PS4 was in rest mode. I will turn it off advise back if it works.
Thanks.
