Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
shockwaveeeTV
Feb 10, 2019Aspirant
this has been happening lately where the xr500 disconnts randomly at any time it wants any help? firmware is uptodate
Feb 11, 2019Guru - Experienced User
What FW is currently loaded?
- shockwaveeeTVFeb 11, 2019AspirantFirmware is 2.3.2.40 the model of the modem is the NG cm1000 and also dont know what a mff is.
- StevecookFeb 11, 2019ApprenticeWhen I have the router page open and looking at the geo filter when I'm playing bo4 I keep getting a message that I'm no longer connected to my router or check internet connection. I have to disconnect from my wireless internet and reconnect then it reconnects to the router. It does this every 15 minutes or so. I don't think I'm losing internet as it doesn't drop me out of the game or I don't get a connection error. It seems like I'm losing connection to the router. As soon as I disconnect and reconnect it communicates again. What would be causing this.
- DrunkMonk74Feb 12, 2019Star
Can confirm I'm getting this now. It's got worse and worse now. It's almost every 10 mins. Doesn't matter if on WiFi or wired connection, everything drops. Running latest firmware 2.3.2.40, and this affects both wired and wireless connections. It's really bad now and would love some kind of update on when we can expect an update that resolves this issue. It's been going on for some time now.
