Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Xenos8
Apr 25, 2019Apprentice
My internet connection drops once a week, usually during the middle of the night when no one in the household is online. We wake up to find no Internet, but VoIP phone still working. I reboot the XR500 and modem and connection is restored for another week. I am on the latest firmware and have done factory reset per suggestions in this thread. Please help.
Apr 25, 2019Guru - Experienced User
You might try reverting back to v32 FW, reset and setup from scratch and see if it still happens...
- Xenos8Apr 25, 2019Apprentice
ISP is Optimum Online. Modem is supplied by them Arris TM1602. It's not a WiFi issue or signal issue because when I lose Internet the internet light on the router goes from green to red.
- FURRYe38Apr 25, 2019Guru - Experienced User
Try reverting back to v32.
Also seen problems with Arris TM1602 modems. These are not the greatest modems. You might change out this modem for a NG CM1000/1100 or Arris SB6183/8200 or Motorola MB7420/8600.
- Netduma-FraserApr 25, 2019NetDuma PartnerDowngrade and see if that resolves your issue, if not then it sounds to me as though the DHCP lease is trying to renew but failing, in which case setting reserved/static IPs for your devices may resolve it.
