Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
CooLRuNNinGS
May 08, 2019Tutor
Would someone mind sending me the firmware fix as I’m still experiencing issues 12 months since purchasing the xr500?
Many thanks.
Many thanks.
Netduma-Fraser
May 08, 2019NetDuma Partner
That's great to hear, thanks for the updates!
Here you are: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
- Xenos8May 14, 2019Apprentice
Just wanted to post a final update. The firmware patch fixed my issue. Router has stayed connected to Internet for just about two weeks no. Thanks very much!
