Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
CptZivaX91
May 15, 2019Aspirant
We are having the same issue. I will still shows as connected to my network but no internet and we have updated the firmware on our router to that version.
We have 2 XBOX One S's and I will be in a lobby and then all of a suddent be dropped and my husband who is just on a webpage will get the no internet error but shows him completely connected to the network but no internet and our internet service provider says we have not lost internet to the modem in months.
I have also swapped out the ethernet running between the modem and the router.
ANy other suggestions besides that firmware update because I have it and it has done nothing.
- Netduma-FraserMay 15, 2019NetDuma PartnerAre the consoles in instant on mode or any other devices in standby mode? If so turn that off and see if that resolves your issue please.
- RenkokunMay 19, 2019Aspirant
I am having the same issue after 5-10mins my XR500 drops internet and I can't even access the router anymore, if I restart the router it works again for 5-10mins, I don't have any Xbox I tried to update the firmware with the one you provided + factory reset but I still have the same problem. I don't know what else I can do
- Netduma_AlexMay 20, 2019NetDuma Partner
Are you using the hotfix firmware?
When the internet goes down, is it still possible to connect to the internet through your modem (bypassing the router)?
If you can connect via the modem even when the router fails, it means we have a router problem. If you can't connect at this time, that suggests a modem or line problem.
