Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
CeeDaRula
Jun 08, 2019Aspirant
So I am having the same issue with the drop of internet and the only way to get it to come back up is to turn off the router for a few and turn it back on then it works fine as long as anything hardwired is online. If anything goes on standby for more then 4- 5 hours I wil lose connectivity. I did the hot fix to no avail. I'm hoping there is a update soon as this is becoming very annoying.
