Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma_Alex
Jul 05, 2019NetDuma Partner
When you say you've got the current firmware, you mean the hotfix firmware right?
Surverok wrote:
I have the current firmware and ive read through the hundreds of other posts about dropping internet for two days straight now obviously something else is the problem
Surverok
Jul 07, 2019Aspirant
I mean I go to the dumos website and it saya there is not an update available... Meaning to me that I habe the most current version
- Netduma_AlexJul 08, 2019NetDuma Partner
Could you give this firmware a go?
https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
- sivolaJul 19, 2019Tutor
I have the XR500 from not long ago, i just installed the new firmware, but i am really frustrated that such a high price router have issues with LAN! i really hope this hotfix will solve the problem, because telling us to turn off instant on is not a solution as this issue also happens with AppleTv on my part.
Every 2-3 days i have to reboot the router because all lan connected devices stops working...Please make sure this is solved...- NMS356Aug 28, 2019Guide
Recently I have been having the same issue with the decice dropping internet connectivity. I have to repower the router. I travel a lot and can't reset while I'm away so I lose my thermostat and home security cameras. This device is only a year old. What is the fix?
