Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Xenos8
Jul 17, 2019Apprentice
So I thought I was in the clear. Internet has been up and stable for over a week. Just got a call from my daughter, NO INTERNET! Walked her through rebooting modem and router. Internet is restored, POOF. It kills me that I am never home to look at the log and see what's going on. They never seem to show anything by the time I get home from work. An there is no way I am enabling remote management! As I've stated before, I doubt its my ISP because Voip phone is working when this happens and all lights look normal on ISP modem. Last week when this happened, besides the rewiring I also removed the USB drive I had in port 1 of the XR500 and disabled geo-filtering. Router is basic configuration now. I am going to factory reset it one more time and if that doesn't work try for an RMA through NetGear. This is ridiculous.
Netduma-Fraser
Jul 17, 2019NetDuma Partner
I think an RMA might be a good idea as not everyone has these issues so while it may be something that can be fixed in firmware there may be an issue with the router you have specifically.
- CeeDaRulaJul 20, 2019Aspirant
I think a RMA is warranted since the router has been out for a year and no permanent fix for this issue people are having has been available.
- sivolaJul 20, 2019TutorWhat do you mean by RMA?
- ZurkeyDurkeyJul 21, 2019GuideHe means a return/exchange under warranty. RMA is the name of the process.
- Netduma-FraserJul 23, 2019NetDuma PartnerSorry to hear you're having this issue as well sivola, while we wait for a firmware update that can fix the issue have you tried the workarounds previously mentioned in the topic?
- Xenos8Jul 26, 2019Apprentice
So I called NetGear to initiate the RMA process of the XR500. After some "gentle persuasion" they agreed to send me a new router. It should arrive Monday. I will let you know if it fixes my problem. I think it will because my old Asus has been up for nearly two days without a problem. What I found interesting in my RMA ticket is that the replacement router is listed as XR500 100NAS (old one is listed as just XR500). I am wondering if its a slightly newer version of the XR500?
- schumakuJul 26, 2019Guru - Experienced User
Xenos8 wrote:What I found interesting in my RMA ticket is that the replacement router is listed as XR500 100NAS (old one is listed as just XR500). I am wondering if its a slightly newer version of the XR500?
No. XR500-100NAS designates version 1 (-100) and NAS packaged / designated for North America (power supply, documentation, wireless region).
- Netduma-FraserJul 27, 2019NetDuma PartnerGlad to hear you're getting it replaced, keep us updated!
- Xenos8Jul 30, 2019Apprentice
So I received the replacement XR500 on Saturday and set it up last night. This time I went through the set up cable connected to router instead of wireless. I let the router update the firmware to V2.3.2.4Na. I also ordered all new Cat6 Ethernet cables and replaced everything connected to router. Only time will tell if this one is stable. I hope so. BTW, my old Asus router was running for 5 days without issue while I waited for the XR500 replacement. So I am pretty sure nothing is wrong with my modem (also replaced a few weeks back) or ISP. Fingers crossed!
- Netduma-FraserJul 30, 2019NetDuma PartnerGlad to hear you got the replacement, keep us posted and let us know if you have any questions!
- sivolaJul 31, 2019Tutor
Did it work? changing to other cable makes the difference? sounds weird to me, for me on another (much cheaper) router everything works fine and with XR500 any configuration i tried doesn't work and unforuntaly for me i don't have an easy option to get a replacement in my country the service is bad from netgear (which i only found out after buying and having this issue...)
- Xenos8Jul 31, 2019Apprentice
You are correct that ethernet cables connected to ports 1-4 should have nothing to do with the router losing its connection to the Internet. The device connected to a bad cable on port 1-4 would have an issue only. The only cable that should count is the one connected to the WAN port and ISP modem, however, I decided to replace them all just in case. Keep in mind my old Asus router had no issue what so ever with the old cables. So far the replacement XR500 NetGear sent me has been running fine for 48 hours. The old XR500 would lose its connection after about a week. So I still need to give the new replacement some time before I claim success. Side note: after I applied the patch for the current firmware (given to me by the awesome folks that are part of this community forum!) the old XR500 was fine for a month and then it crapped out........
- FURRYe38Jul 31, 2019Guru - Experienced User
Are you using the router with or with out a external LAN switch? Just curious.
Xenos8 wrote:You are correct that ethernet cables connected to ports 1-4 should have nothing to do with the router losing its connection to the Internet. The device connected to a bad cable on port 1-4 would have an issue only. The only cable that should count is the one connected to the WAN port and ISP modem, however, I decided to replace them all just in case. Keep in mind my old Asus router had no issue what so ever with the old cables. So far the replacement XR500 NetGear sent me has been running fine for 48 hours. The old XR500 would lose its connection after about a week. So I still need to give the new replacement some time before I claim success. Side note: after I applied the patch for the current firmware (given to me by the awesome folks that are part of this community forum!) the old XR500 was fine for a month and then it crapped out........
No LAN switch. XR500 connected to ISP Modem via Cat6 ethernet cable. Thats it.
