Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Stevecook
Oct 08, 2019Apprentice
I just updated mybrouter to new est firmware yesterday and having issues. My settings for auto ping host keeps resetting. I have to recheck it but still doesnt auto ping host. Internet keeps dropping out as well now.
- StevecookOct 08, 2019ApprenticeIt wont even give me my ping now. It gives all the other info like tick rate server etc but not what my ping is.
- FURRYe38Oct 09, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update? I would try this first.
What browser are you using?
Stevecook wrote:
I just updated mybrouter to new est firmware yesterday and having issues. My settings for auto ping host keeps resetting. I have to recheck it but still doesnt auto ping host. Internet keeps dropping out as well now.- Netduma-FraserOct 09, 2019NetDuma PartnerWhat browser are you using to access the interface? Does the browser save your cookies? What devices get disconnected wired/wireless? Do you see the ping number but just not the graph line for ping?
- gt9484Oct 09, 2019TutorI have upgraded and downgraded it many times I use Chrome I have had poor performance since the start...
