Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Oct 29, 2019NetDuma Partner
That's fine, no other settings need be changed. It could be a handshake issue between them you're right, if you reboot them one at a time that may resolve it. Definitely keep a reset in your arsenal in case that doesn't work.
Sereph102889
Oct 31, 2019Tutor
So I came home last night from work and did a factory reset on the router. This time when it came time to start the router setup, the first thing it did was pop up a message saying: "changed router IP adress to xxx.xx.xx.xx" to avoid communication issues with ISP Modem". I then let it go through the entire setup process by itself, using automatic settings for everything. So far the network seems more crisp, I guess is how I could describe it. Anyways, I will post back if the issue continues. I actually don't think it was power-cycling anymore after something the router did night before last. I think it was losing all internet connection from the modem for some reason. Hopefully this resolves the issues.
- Sereph102889Nov 13, 2019Tutor
Figured I would post back now that it's been a few weeks. The factory reset that I performed seems to have fixed every single issue I had with this router. I would also like to mention that at the same time as the factory reset, I also power cycled the ISP modem and made sure that they both came back up at the same time. When doing this, I received a message telling me that the router had changed it's IP Address to a specific IP in order to better communicate with the ISP modem and reduce the possibilty of issues. I never got this message on initial unboxing and setup of the XR500, and since I performed the factory reset I have had 0 issues. My connection is better, upstream and downstream numbers are within 99% of a hardline connection to the modem, hell, sometimes with Wifi the router gives me 115mb down when I'm only paying for 90 down.
TLDR: Had the same issues as lots of others in this thread, did a factory reset and power cycled ISP modem all at the same time, got a message that the router updated it's IP address to better communicate with ISP modem, and have had 0 issues since. This seems to have fixed all my issues.
