Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma_Alex
Nov 22, 2019NetDuma Partner
Hmm...
Could you set your current WAN settings as Static?
To do this:
- Get the WAN IP from System Information in DumaOS
- In Settings > Internet setup, set your IP as the WAN IP from previous step
- Set Subnet Mask as 255.255.255.0
- Set Gateway IP as the WAN IP but with the number after the third dot as a 1
- Example, 192.168.0.45 becomes 192.168.0.1
- Set DNS server as whatever you like, if not sure use 8.8.8.8, then 8.8.4.4, then Gateway IP
Hopefully that will stop it from getting thrown off.
A_Monto
Nov 24, 2019Aspirant
Ok i've pretty much pin pointed my internet disconnectivity issues to the afforementioned dos attacks on my router. I have a vpn up which I thought would help with this but it's still getting through, is there something I can do to stop these attacks so I don't disconnect anymore?
- FURRYe38Nov 25, 2019Guru - Experienced User
Have your ISP change the WAN IP address that comes thru the modem.
A_Monto wrote:Ok i've pretty much pin pointed my internet disconnectivity issues to the afforementioned dos attacks on my router. I have a vpn up which I thought would help with this but it's still getting through, is there something I can do to stop these attacks so I don't disconnect anymore?
- Netduma_AlexNov 25, 2019NetDuma Partner
Could you paste in some of the logs that mention the DoS attack?
- A_MontoNov 25, 2019Aspirant
Here are the logs from my router, let me know what next steps I can take.
[admin login] from source , Monday, November 25, 2019 17:18:39 [UPnP set event: del_nat_rule] from source , Monday, November 25, 2019 17:17:12 [DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, November 25, 2019 17:16:23 [UPnP set event: add_nat_rule] from source 192.168.1.12, Monday, November 25, 2019 17:14:34 [UPnP set event: del_nat_rule] from source 192.168.1.12, Monday, November 25, 2019 17:14:10 [UPnP set event: add_nat_rule] from source 192.168.1.12, Monday, November 25, 2019 17:09:24 [DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, November 25, 2019 17:05:43 [DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, November 25, 2019 17:01:36 [DoS Attack: SYN/ACK Scan] from source: 148.251.48.231, port 50002, Monday, November 25, 2019 16:52:39
- Netduma_AlexNov 26, 2019NetDuma Partner
Under Settings > Setup > WAN Setup, make sure that Port Scan and DoS protection are NOT disabled.
