Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
A_Monto
Nov 24, 2019Aspirant
Ok i've pretty much pin pointed my internet disconnectivity issues to the afforementioned dos attacks on my router. I have a vpn up which I thought would help with this but it's still getting through, is there something I can do to stop these attacks so I don't disconnect anymore?
Nov 25, 2019Guru - Experienced User
Have your ISP change the WAN IP address that comes thru the modem.
A_Monto wrote:Ok i've pretty much pin pointed my internet disconnectivity issues to the afforementioned dos attacks on my router. I have a vpn up which I thought would help with this but it's still getting through, is there something I can do to stop these attacks so I don't disconnect anymore?
