Stevecook
Sep 04, 2018Apprentice
Xr500 drops internet
My router is dropping internet everyday now. I did a factory reset and still does it. Once I turn power off and back on the internet comes back. It drops everything wireless and wired devices. I rest ...
Sep 04, 2018Guru - Experienced User
I would try Manual channels and see if this helps any, 1, 6 or 11 and any unused channels.
Possible ISP modem issue between that and the router.
What happens if you apply the very 1st FW for the XR500, do a factory reset then setup from scratch. If it still happens here, could be FW or HW at the router.
