Freekless
Jan 24, 2019Follower
XR500 drops internet
My XR500 has been dropping Ethernet and the WiFi continues to work perfectly fine please help.
Jan 28, 2019Guru - Experienced User
What FW is currently loaded?
- RiverstyxxFeb 02, 2019Aspirant
You should be able to log into your modem by goint to address 192.168.100.1 and logging in with admin and password for the password.
I would check the signal levels and google what they should be for your ISP. There might be a signal issue with the modem.
