Freekless
Jan 24, 2019Follower
XR500 drops internet
My XR500 has been dropping Ethernet and the WiFi continues to work perfectly fine please help.
Jan 28, 2019Guru - Experienced User
What FW is currently loaded?
Riverstyxx
Feb 02, 2019Aspirant
You should be able to log into your modem by goint to address 192.168.100.1 and logging in with admin and password for the password.
I would check the signal levels and google what they should be for your ISP. There might be a signal issue with the modem.
