pursuit4perfect
Aug 05, 2020Aspirant
XR500 Duma 3.0
Hello, is there a place i can sign up for Duma 3.0 beta test or is it over? When do we expect 3.0 to be released? Thanks.
Netduma-Fraser
Aug 05, 2020NetDuma Partner
Yes you can sign up for the beta here: http://www.netgearinnovation.com/dumaos-beta/index.html
Invites are still going out, they happen in batches so it won't be instant. Public release depends on the stability during beta, it will likely roll into an open beta before official launch.
- pursuit4perfectAug 05, 2020Aspirant
Thanks for the quick response!
sounds like no immediate date for broader public availability through Beta.
does the new R2 have Duma 3.0 on day 1? i.e. can use it immediately if you buy the new router? Thanks.
- Netduma-FraserAug 05, 2020NetDuma PartnerNo immediate date no but we're still inviting people to the beta so everyone still has the chance to try it before then.
Yes the R2 releases with 3.0 pre-installed so you can use it right away.
