Iamcity
Oct 21, 2020Tutor
xr500 duma os 3.0 considerable low speeds
Ever since i updated my xr500 to duma 3.0 beta i'v been getting low speeds with wired connection. i have a laptop and my xbox one connected via wired. I have spectrum and have the 1gb download and 40...
Netduma-Fraser
Oct 22, 2020NetDuma Partner
If it is a specific issue with the beta then please post in the beta section. Before doing that try disabling QoS completely from the Congestion Control 3 line option menu in the top left of the panel and see if speeds are restored.
Iamcity
Oct 22, 2020Tutor
So it worked when i disabled QOS. So why do i have to disable that for my speeds to be correctly? Second, when i disable Qos why does it keep enabling itself? So my download speed went back up but my upload speed is not right.
- Netduma-FraserOct 23, 2020NetDuma PartnerLikely because the QoS settings you had enabled were restricting the speeds, what were your QoS settings?
