Iamcity
Oct 21, 2020Tutor
xr500 duma os 3.0 considerable low speeds
Ever since i updated my xr500 to duma 3.0 beta i'v been getting low speeds with wired connection. i have a laptop and my xbox one connected via wired. I have spectrum and have the 1gb download and 40...
Iamcity
Oct 22, 2020Tutor
So it worked when i disabled QOS. So why do i have to disable that for my speeds to be correctly? Second, when i disable Qos why does it keep enabling itself? So my download speed went back up but my upload speed is not right.
Netduma-Fraser
Oct 23, 2020NetDuma Partner
Likely because the QoS settings you had enabled were restricting the speeds, what were your QoS settings?
