Iamcity
Jun 18, 2020Tutor
XR500 Duma OS 3.0
What happened to DUMA OS 3.0? I'm starting to think that I bought this router for no reason. I mean I can control what servers I connect to but i did expect to have lower pings. I watched the video o...
Netduma-Fraser
Jun 18, 2020NetDuma Partner
Initial batch of testers were selected late last week for the XR500 so more batches and betas for the other routers will kick off soon as well. Your settings may not be optimal so take a look at these optimal settings guides which should help: http://support.netduma.com/en/support/solutions/folders/16000090646
MrPChulo
Jul 07, 2020Aspirant
I am hoping with the new DUMA OS update will fix my issue. The QOS and GEO filter made my sons PC ping ridiculously high (100-200). the other issue I had was that even though i saved the changes on the QOS bandwidth it will go back to 0% and all the devices connected would barely get any bandwidth even though i have 1gig speeds. I had no choice but to turn my router into an access point so all my devices worked properly.
- Netduma-FraserJul 08, 2020NetDuma PartnerMrPChulo I've not seen you make a post regarding that issue so it is likely a settings issue that is easily resolvable. If you make a topic and explain a bit more about the issues you're having then we'd be happy to help.
