Laryke
May 10, 2021Apprentice
XR500 dumaos 3.0 speed test
On DumaOs when I do a connection benchark I got D A+ D, it says that my download speed is under 500, but when I do a speedtest on another site is 900+. And when I change network speed and use auto-de...
May 10, 2021Guru - Experienced User
Its been my experience that the built in tests suites aren't accurate >500mbps because they don't always pick the ideal test server.
I've never used dumaos so can't attest to its accuracy.
If you're hitting full speed when testing manually, then you can setup the manual test speeds.
