Laryke
May 10, 2021Apprentice
XR500 dumaos 3.0 speed test
On DumaOs when I do a connection benchark I got D A+ D, it says that my download speed is under 500, but when I do a speedtest on another site is 900+. And when I change network speed and use auto-de...
Netduma-Liam
May 11, 2021NetDuma Partner
One thing that I would suggest doing would be to double check that the speeds entered into DumaOS are correct, you can do this by clicking the three-line menu in the top right of the interface and then select 'Advanced' and then Network Speeds.
Laryke
May 11, 2021Apprentice
I let the router to choose the speed, I have 1200mbs download si 40-50 upload, and when I installed the router says 960 and 40.
But if I do auto choose speed it’s 300-400 download and 40 upload
- Netduma-FraserMay 11, 2021NetDuma PartnerWe're still improving the results reported by Connection Benchmark so you can ignore that for the moment, if a third party speed test gives you the speeds you expect that is what you'll be getting
