Th3AngryGerman
Jan 03, 2021Aspirant
XR500 DumaOS Geofilter PS5 Issue - Battlefield
Hi everyone, I ran into an issue when trying to use the Geofilter on the XR500 for the PS5. I added the console, set it to Battlefield, and set a 400 mile radius which I what I have done on PS4 w...
Netduma-Fraser
Jan 04, 2021NetDuma Partner
I'm more surprised that Battlefield worked with the Geo-Filter on the PS4 and Xbox as I tested it a long time ago and because it has a server browser the Geo-Filter isn't really needed. Destiny 2 is probably updating the way it works like it has done for PC which is currently not working optimally and we're looking into that. When filtering on PS5 for Battlefield is there anything on the map that appears as blocked?
- Th3AngryGermanJan 04, 2021AspirantNope, nothing blocked and nothing out of the ordinary. I will sometimes use the quick match feature which is why I had it setup that way, but most of the time I use the server browser. The only other MP I play is Warzone but the Geo filter doesn't seem to work for that.
- Netduma-FraserJan 04, 2021NetDuma PartnerIt should work fine for Warzone, does it work on PS4?
I was never able to get it to work on PS4. Every match I would go into was always over 100ms ping, and I had adjusted the range of the Geo filter to see if it would help and it never did.
