Th3AngryGerman
Jan 03, 2021Aspirant
XR500 DumaOS Geofilter PS5 Issue - Battlefield
Hi everyone, I ran into an issue when trying to use the Geofilter on the XR500 for the PS5. I added the console, set it to Battlefield, and set a 400 mile radius which I what I have done on PS4 w...
Th3AngryGerman
Jan 04, 2021Aspirant
Nope, nothing blocked and nothing out of the ordinary. I will sometimes use the quick match feature which is why I had it setup that way, but most of the time I use the server browser. The only other MP I play is Warzone but the Geo filter doesn't seem to work for that.
Netduma-Fraser
Jan 04, 2021NetDuma Partner
It should work fine for Warzone, does it work on PS4?
- Th3AngryGermanJan 04, 2021Aspirant
I was never able to get it to work on PS4. Every match I would go into was always over 100ms ping, and I had adjusted the range of the Geo filter to see if it would help and it never did.
- Netduma-FraserJan 04, 2021NetDuma PartnerIf you post a screenshot of your Geo-Filter and QoS settings I can offer some tips to improve your experience.
