Flexicon
Mar 22, 2022Aspirant
XR500 DumaOS not loaded yet
A few weeks ago my XR500 router, which has been running flawlessly since I got back in June 2021, stopped running DumaOS. Everytime I try to log in to the router I see the following message: DumaO...
Netduma-Fraser
Mar 22, 2022NetDuma Partner
You have to wait for 2 minutes after rebooting to ensure it loads correctly and then it should be fine. The next version should almost eliminate this issue as well.
- FlexiconMar 22, 2022Aspirant
Hey, thanks for the quick reply.
Now do you mean wait 2 minutes after rebooting before trying to access the DumaOS dashboard? Or just wait 2 minutes in general?
Because if it's the latter then my router has been stuck on "DumaOS not loaded yet!" for like a week now.
- Netduma-FraserMar 22, 2022NetDuma PartnerYes once you've rebooted wait 2 minutes before accessing, it can be the accessing part that interrupts the correct loading of DumaOS.
- FlexiconApr 30, 2022Aspirant
So Netduma-Fraser I've tried this a number of times over the last month and no dice. I have even tried rebooting the router over night and only accessing the admin panel in the morning and still I'm seeing the same "DumaOS not loaded yet" error message.
I have also updated the firmware on the router since my last post as a patch was released but that didn't change anything - after updating the router and rebooting it I awaited around 10 minutes this time.
Any other things that I could try to get DumaOS working again?
