ZR4x4
Apr 20, 2022Aspirant
XR500 DumaOS not working
Not sure if this has been asked before but I have updated firmware to the current.134 version. I wanted to delete/rename devices from the Device Manager in DumaOS but all devices are “greyed out” to w...
ZR4x4
Apr 21, 2022Aspirant
I have tried both methods. I can't access DumaOS on Mac because all I get is the "script error." Everything has been reset, unplugged, etc. The only way I can get the dashboard to come up is on iPad Safari, and even then I still cannot make changes to QOS, Device Manager, etc.
Netduma-Fraser
Apr 21, 2022NetDuma Partner
Script error is usually do to accessing via HTTPS instead of HTTP or an Adblocker on your web browser is causing it, do any of those apply?
For example, if you're using Safari they automatically force HTTPS which would cause the error so another browser like Chrome or Firefox should work right away.
- ZR4x4Apr 21, 2022Aspirant
I have tried all of those options. I can send pictures later on to help clarify.
- Netduma-FraserApr 21, 2022NetDuma PartnerIn which case, I would suggest downgrading to .114, doing a factory reset, then upgrading to the latest and don't reset and it will work.
