Ironlion
Apr 28, 2024Aspirant
Xr500 DumaOS os not running
Hey team. I recently purchased an xr500 secondhand from a guy who works in the network industry. Every time I've tried to set it up I end up with a black screen saying "DumaOS is not running!) A fe...
Apr 29, 2024Guru - Experienced User
Has a power cycle been performed after the XR is connected to the ISP modem, then after the XR is online, power it off for 15 seconds then back ON or reboot it from the WEB UI.
Ironlion
Apr 29, 2024Aspirant
Hey Furry
Not too sure what mfr means, but its a Nokia G-1425G-A. I've successfully loaded the latest firmware.
I've performed on/off/on on the ont today, and cycled the xr a few times but not in that order.
Are you saying power cycle/off-on the ont or router prior the reboot the xr in UI?
Cheers
Cheers
- Netduma-FraserApr 29, 2024NetDuma PartnerYes so reboot the ONT, wait a few minutes then reboot the XR and wait a few minutes before trying to access. You may need to go through the Setup Wizard in order to get internet.
- IronlionApr 29, 2024AspirantWill try that tonight and report results Thanks
- FURRYe38Apr 29, 2024Guru - Experienced User
Modem Combo Units:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...Power cycle the XR router one more time after it's connected to the ISP ONT.
Ironlion wrote:
Hey Furry
Cheers
