Rstrauss
May 23, 2020Aspirant
XR500-dumaOS OVERWATCH and high latency
What are the best setting for DumaOS on the xr500 for overwatch seeing a lot of latency (and lag)
May 26, 2020Guru - Experienced User
http://support.netduma.com/support/solutions/folders/16000090646
- Netduma-FraserMay 26, 2020NetDuma PartnerI'd suggest going through our optimal settings guides and then if you still have any issues or questions let us know: http://support.netduma.com/en/support/solutions/folders/16000090646
- RstraussMay 27, 2020Aspirant
I tried it and it didn't seem to help.
- FURRYe38May 27, 2020Guru - Experienced User
So running the plotter program did you see high latency when directly connected to the modem vs with the XR router in between?
Reason for testing this is to see if latency is seen from the ISP side thru the modem or at the router.
- RstraussMay 26, 2020Aspirant
firmware-V2.3.2.56
ISP is Optimum-400MB service-optimum modem is Arris TM1602
Blizzard games thinks it might be packet loss from the router (based on diagnostics that were run on the computer playing Overwatch
That computer is a new MSI gs66 stealth
One way to check latency or ping, run pingplotter.com app on your PC with the pc directly connectec to the modem. No XR router in the middle. Then test with the XR connected, with no wifi radios enabled and just the 1 wired PC connected.
