Rstrauss
May 23, 2020Aspirant
XR500-dumaOS OVERWATCH and high latency
What are the best setting for DumaOS on the xr500 for overwatch seeing a lot of latency (and lag)
May 26, 2020Guru - Experienced User
http://support.netduma.com/support/solutions/folders/16000090646
Rstrauss
May 26, 2020Aspirant
firmware-V2.3.2.56
ISP is Optimum-400MB service-optimum modem is Arris TM1602
Blizzard games thinks it might be packet loss from the router (based on diagnostics that were run on the computer playing Overwatch
That computer is a new MSI gs66 stealth
- FURRYe38May 27, 2020Guru - Experienced User
One way to check latency or ping, run pingplotter.com app on your PC with the pc directly connectec to the modem. No XR router in the middle. Then test with the XR connected, with no wifi radios enabled and just the 1 wired PC connected.
