Rstrauss
May 23, 2020Aspirant
XR500-dumaOS OVERWATCH and high latency
What are the best setting for DumaOS on the xr500 for overwatch seeing a lot of latency (and lag)
Netduma-Fraser
May 26, 2020NetDuma Partner
I'd suggest going through our optimal settings guides and then if you still have any issues or questions let us know: http://support.netduma.com/en/support/solutions/folders/16000090646
Rstrauss
May 27, 2020Aspirant
I tried it and it didn't seem to help.
- FURRYe38May 27, 2020Guru - Experienced User
So running the plotter program did you see high latency when directly connected to the modem vs with the XR router in between?
Reason for testing this is to see if latency is seen from the ISP side thru the modem or at the router.
- Netduma-FraserMay 27, 2020NetDuma PartnerDid you try both our suggestions?
