jdcraft1
May 22, 2021Follower
XR500 DUMAOS
Logged in to XR500 router but the login is not secured, how do I fix this?
michaelkenward
May 23, 2021Guru - Experienced User
jdcraft1 wrote:
.... the login is not secured, how do I fix this?
Logged in with what? I assume an app, that's what this section is for. But who knows?
What says that? What messages do you see?
It is often something to do with the browser. Nothing to do with "security".
But you don't provide enough detail for anyone to do more than guess.
You have posted your message in the section of this community given over to Apps and Services. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
