Deijeneiro
Aug 12, 2020Guide
XR500 Dumo OS 3.0 beta
Hi , I would like to know if I’m succesfully registered for the beta? Since its been like two months ago and people already recieved emails. Username should either be Deijeneiro or Marvin. This is tak...
D3vious
Aug 16, 2020Star
I would love the link too!
Does the beta address the QOS not working as designed when connected via a vlan?
Cheers!
Netduma-Fraser
Aug 17, 2020NetDuma Partner
mc1500mc You don't appear on the Geo-Filter yourself so that will be someone you're connected to. You're likely showing the server and a player at the same time. If there is still a connection it will appear but then disappear shortly afterwards. Device manager fixes are coming in next build. That error is because you have probably rebooted and the name of the device changed or was removed. If you add the device back with the same name or reset it will be fixed. Also please post errors on the beta build to the beta section that I gave you the link to on the Netduma forum.
- mc1500mcAug 19, 2020Aspirant
The link you provided brought me to the Netgear website where i created an account, but it didnt take me to the Beta build link. im sorry, i am lost on here. There is way too many links on this website.
