fbry7177
Jun 15, 2018Follower
Xr500 Ethernet limited to 100Mbit
Hello, I have gigabit service from my ISP. When plugged in to the wall I at least get 250~500Mbit download speeds but when I try to download the same exact file from the same exact website (Microsof...
ReddieEX
Jan 12, 2019Aspirant
Hey there,
actually i got the same problem over here. but i dont know if its just a bug in dumaos.
i could see the following in the device manager app
and Link Speed is at 100 Mbits. My Setup is pretty easy: Cable ISP Router Gigabit > XR500 via Cat 5e > Client Machine via Cat 5e
I'll try it with cat 6 or 7 within the next couple of days and post a reply.
Netduma-Fraser
Jan 12, 2019NetDuma Partner
I can't see the picture yet as it hasn't been moderated. Is this the WAN port or specific ports for devices?
- ReddieEXJan 12, 2019Aspirant
hey fraser,
the wan port is on 1000 GBits, the LAN Ports are all (2 connected via cat 5e) at 100 MBits
- FURRYe38Jan 13, 2019Guru - Experienced User
Swap LAN cables to test.
Swap network adapters if possible. Ensure that network adapters are rated for 1000Mb connection rates.
- Netduma-FraserJan 13, 2019NetDuma PartnerCheck the link speed on windows, is it full duplex 1000mbps? If not change it, does that work? If it doesn't have as an option then your device doesn't support more than 100mbps and device manager is showing correctly.
- ReddieEXJan 14, 2019Aspirant
hey there again, tested it now with Cat 6 and Cat 7 cables and now it changed to gigabit ethernet. thought that cat 5e is enough for gigabit communication but well, nobody learn out. Just use always Cat 6 or higher nowadays.
- schumakuJan 14, 2019Guru - Experienced User
The point is that some older CAT5 or CAT5E cables have two pairs (four strands) only - this does limit to Fast Ethernet (100 Mbit/s max). CAT5E is sufficient for Gigabit Ethernet, permitting there are four workable pairs (eight strands) inside.
- FURRYe38Jan 14, 2019Guru - Experienced User
Glad it's working now. Enjoy. :smileywink:
