ErikE
Jun 26, 2018Guide
XR500 Ethernet ports die randomly?
So I contacted NetGear within the first 30 days of using the router with an issue where the ethernet ports stop connecting randomly. They instructed me to manually reapply the updated the firmware (2....
Netduma-Fraser
Aug 31, 2018NetDuma Partner
Sent you a PM Mikey
PolikosFoinix
Sep 29, 2018Star
I am having the same problem as everyone else, replaced the router via RMA. The new XR500 that I received worked for a few months and then started doing the LAN port shutdown again. I have tried going back to previous firmware (from Support), up to current and still no effect. I've tried checking the Disable Port Scan and DoS Protection in the WAN Setup because I always get a slew of DoS Attacks listing in my logs, which are coming from IPs assigned to Microsoft, Bungie, Blizzard, Steam, UPlay, etc. These are all known and good, so why is the Duma OS flagging traffic as an attack??? I would greatly appreciate any ideas because I'm out of them.
- Netduma_JackSep 30, 2018NetDuma PartnerIt’s actually a base NETGEAR setting and it’s nothing to worry about at all. Just general internet white noise. If you google the message you’ll see many threads all over this forum saying the same thing.
So in summary, no need to worry!- Netduma_JackSep 30, 2018NetDuma PartnerBut as for LAN ports dying, it’s hard to know what the cause is. Is it happening across multiple devices, or just a particular device? And are you on the latest firmware (ends in .32)?
If the issue continues I recommend you contact Netgear’s official support.- PolikosFoinixSep 30, 2018StarNormally I would agree with you, however that is the only thing showing up in my logs before than LAN Ports disable. So that is my natural conclusion that it is the root cause of the LAN Ports disabling. When it happens it shuts down all LAN ports with no warning or logged reason. I am on the latest firmware .23, and there is nothing new on my network that my previous R7000 had any problems with. I never had this happen in 3 years of owning an R7000 now it's happening constantly on what is supposed to be the best gaming router. When I have to reboot once a day to be able do simply game its highly frustrating.
