ErikE
Jun 26, 2018Guide
XR500 Ethernet ports die randomly?
So I contacted NetGear within the first 30 days of using the router with an issue where the ethernet ports stop connecting randomly. They instructed me to manually reapply the updated the firmware (2....
Netduma-Fraser
Jun 26, 2018NetDuma Partner
I've sent you a PM with a firmware that may resolve the issue.
CCOPELAND
Apr 18, 2019Guide
I am having the same problem my wifi works great but I have to reset my router sometime twice a day to get my ethernet ports to work.
- PolikosFoinixApr 18, 2019Star
CCOPELAND, welcome to the party. Most likely you have an XBox that is set to instant on within your network. You have two choices to solve the problem at present: 1. Disable the Instant On mode from your XBox. 2. Put a switch such as (NETGEAR 5-Port Gigabit Unmanaged Switch (GS605NA)) between your XBox and your XR500. The XBox's Instant On Mode is causing an internal conflict on the XR500 that disables the LAN ports. Either one of the two options will correct your problem.
- CCOPELANDApr 18, 2019GuideThank you but why did it just start doing this I've had it for almost a year and never had this problem.
- C1R3Apr 18, 2019TutorDid you just recently wire up an xbox? I've had this prob since day one. Many firmware updates later and the problem still persists. I wouldn't hold your breath for a real fix. Start researching a new router.
- FURRYe38Apr 18, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the Mfr and model# of the ethernet switch if one is in the configuration.
What wired devices do you have connected to the LAN ports?
CCOPELAND wrote:
I am having the same problem my wifi works great but I have to reset my router sometime twice a day to get my ethernet ports to work.- CCOPELANDApr 18, 2019GuideXr500 is the router it connected to a netgear modem supplied by frontier. The firmware is the most current and I do not have a switch connected.
What LAN devices do you have connected to the router?
Please try downgrading to v32 FW. Factory reset and setup from scratch after the downgrade.
