Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
Jan 16, 2019Guru - Experienced User
Try a different USB drive by chance?
When connecting it, are you rebooting the router with the drive connected then checking status?
Netduma-Fraser
Jan 16, 2019NetDuma Partner
Could this be the cause?
"Some USB external hard drives and flash drives require you to load the drivers onto the computer before
the computer can access the USB storage device. Such USB storage devices do not work with the router."
Otherwise try a different USB port on the router
- PixysJan 16, 2019Guide
Otherwise try a different USB port on the routerNo, it is not the cause: it would not explain why it works when the drive is formated in NTFS. I tried all the USB ports already, beside, same, it works with NTFS, Fat32 and exFat. I also used a simple USB key: same behavior, it works in NTFS, Fat32 and exFat but not with EXT4.
Note also the LED of the router are on when the disk is plugged so the router sees the disk.
Everything points toward a filesystem support issue.
- Netduma-FraserJan 16, 2019NetDuma PartnerWould recommend you contact Netgear directly through http://support.netgear.com/ as it's a hardware issue and so I'm limited on what advice I can give as I'm from the software company Netduma
- PixysJan 17, 2019Guide
OK, thank you. I'll try to update the thread with the outcome
