Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
Jan 16, 2019Guru - Experienced User
Try a different USB drive by chance?
When connecting it, are you rebooting the router with the drive connected then checking status?
Pixys
Jan 16, 2019Guide
The HDD is correctly detected when it is formated in NTFS, Fat32 or exFat and in EXT4 it works normaly when plugged on my computer.
Exactly the same behavior with a simple USB key. So the problem is not related to the HDD.
I did both: reboot before and after. I also did a factory reset.
