Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
Netduma-Fraser
Jan 23, 2019NetDuma Partner
Hi Pixys, I've passed this to a colleague who will escalate your case to hopefully get you the support you need on the matter.
Pixys
Jan 23, 2019Guide
Hello,
Thanks a lot.
I continued to tset and I made an interesting discovery: it works when the usb key / HDD are formatted in EXT3. It does not work in EXT4.
It feels like the module kmod-fs-ext4 is missing in the Linux kernel of DumaOS...
- Netduma-FraserJan 24, 2019NetDuma PartnerGreat catch, thanks for updating us. The team will find that really helpful when they take a look. Do update your support ticket with that information as well please.
- PixysFeb 05, 2019Guide
Hello,
Unfortunately the ticket is closed. Also it seems to be related to the OS and not the hadware.
That means I have to wait for the next firmware, hoping I pointed you to the right direction and the fix will be included.
Based on the firmware frequency releases, I feel I might have to wait for a very very very long time... and maybe forever.
Next time, I will check the brands that open sourced their fimrwares in order to be independant of the good will of the provider...
- Netduma-FraserFeb 05, 2019NetDuma PartnerAre you unable to re-open the ticket? Hopefully it'll be quicker this time around for a new update, let us know when it arrives if it resolves your issue.
