Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
Netduma-Fraser
Feb 05, 2019NetDuma Partner
Are you unable to re-open the ticket? Hopefully it'll be quicker this time around for a new update, let us know when it arrives if it resolves your issue.
Pixys
Apr 22, 2019Guide
For someting that was supposed to be quick to deliver and fix, it is still not so I think I will trash this router and go to a competitor.
After all, the market is free. It is just a shame that Netgear lies on the specs of his own product. I would have time to waste, I'd sue them.
- Netduma-FraserApr 23, 2019NetDuma PartnerWe you able to re-open your ticket and get an update on this? Sorry to hear you're considering another router due to this.
- PixysApr 23, 2019Guide
No, they keep closing it. Netgear wants me to buy a maintenance package to investigate this issue, I fought for 30 minutes on the phone last time. There is noway I'm gonna buy a maintenance package because someone somewhere is incompetent.
Also they consider the router is working and that it is a Duma OS issue. From a client perspective I don't give a **bleep**: as long as I cannot use another OS, Netgear or Duma is the same for me and Netgear is responsible for delivering a product that matches the requirement they sell.
I am thinking about the ASUS RT AC88U, the good thing is I could even use DD-WRT with it. Freeing me from bad OS if needed. What do you think?
- Netduma-FraserApr 23, 2019NetDuma PartnerSorry to hear that, I can't comment on that as I'm not familiar with it. I've raised this with the team as they should not be dismissing your issue.
It won't change anything. Piece of advice, stop giving hollow promises because you are not responsible for the incompetency of your employer but giving promises makes you responsible...
Honestly, you should close this topic, Netgear / Duma has a reputation of not delivering what is promissed and you are perfectly aware as you handle this forum. One example: the HybridVPN functionnality that has been been promissed for months and just partially implemented.
The frequency of the firmware releases is just ridiculous. If Netgear/Duma is not able to provide good firmwares, at least open the source code, competent people will do the job... for free
- schumakuApr 24, 2019Guru - Experienced User
In defense of Netduma-Fraser by yet another Netgear customer: Netduma is a supplier for some of the technology implemented on the Nightawk Pro Gaming routers, not the vendor or maker of the complete router. The hardware, the base platform OS, and many services like ReadyShare are coming from Netgear. Unfortunately, Netgear has a looong history of broken and incomplete ReadyShare (SMB) implementations on many of their consumer class products. Bottom up, many external storage devices are not recognized, due to various possible reasons (e.g. different partition schemes), USB power, basic USB device detection, ... on any router models. The community is full with these. Let's also take the example that none of these products does come with WS-Discovery - the de-facto industry standard on workgroups replacing the legacy NetBIOS host discovery and name resolution in newer Windows 10 editions - "just" implementing SMB3 alone doesn't make it workable. Comparing to all this, the absence of a working ext4 (geee, exotic for the majority of the Netgear customers) file system support, would be really a snap to fix - I can't agree more. However, the true standard file systems for the typical Netgear customers are NTFS, plus more and more exFAT - the standard file systems for external storage does come from the factory.
Can't find any discussion thread with your participation describing of what HybridVPN functionality you expected or what was promised and not delivered finally - following a long wait. I have my ideas what i would expect from a true HybridVPN implementation, like the ability to keep up multiple VPN sessions (different regions, different providers), and associate either services or local hosts accordingly. This wasn't promised however, unless I have missed something.
- PixysApr 24, 2019GuideMy problem is a pure software issue: the lack of support of ext4 is probably due to a missing option in the kernel settings. Nothing hardware related. I invite you to test yourself. Also it is quite surprising that a router running a Linux based OS is not able to handle the main Linux filesystem.
Moreover, what is not acceptable is the fact that Netgear claims their router supports ext4. I checked the specs before I bought it, you can have a look as well.
About the HybridVPN functionality, it is just a joke that it supports only a couple of VPN providers.
But I've learned my lesson, Netgear, it is over for me (and the people around me as well, of course) - schumakuApr 24, 2019Guru - Experienced User
Pixys wrote:
My problem is a pure software issue: the lack of support of ext4 is probably due to a missing option in the kernel settings. ... I checked the specs before I bought it, you can have a look as well.Nothing wrong with your complaint ref. the broken ext4 support as I said before. Christian_R please take care of this issue on all XRnnn routers - ext4 is supported, so it has to be workable.
Pixys wrote:
About the HybridVPN functionality, it is just a joke that it supports only a couple of VPN providers.Sorry, that's nonense. HybridVPN allows to import any provider OpenVPN config with the inline certificates in the HybridVPN Advanced section. FMI http://support.netduma.com/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
- PixysApr 24, 2019GuideI won't debate about the HybridVPN functionality, this is not something I bought when I chose this router (the functionality did not exist at that time).
That being said I will see again if NordVPN provides config with the inline certificates - schumakuApr 24, 2019Guru - Experienced UserThey do - just download you account config...
- PixysApr 24, 2019GuideGood to know, thank you
- Netduma_JackApr 24, 2019NetDuma Partner
Hi Pixys - in case you're not aware, Hybrid VPN is compatible with any Open VPN provider, you just need to select the advanced option when setting it up and you then input the Config File. Full instructions here: http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
Yeah Netduma_Jack ... as I wrote some posts above already 8-)
Indeed it works. Nice functionality.
My quick judgement was based on the initiale release that did not support various VPN providers.
Hi,
For my own sanity, could someone test as well?
I tried exFat on 3 different USB sticks, 1 SSD, 1 HDD, different cases. It is not recognize either... Of course I don't apply any restriction on the USB devices.
So far only NTFS and HFS+ are recognized.
Firmware version V2.3.2.40
Thanks
I haven't said the XR500 (nor any other Netgear router officiailly) does support exFAT ... just that this is coming up more and more, becoming a standard.
From the fine manual, p.121 ff.
The router supports the following file system types for full read/write access:
• FAT16
• FAT32
• NTFS
• NTFS with compression format enabled
• Ext2
• Ext3
• Ext4
• HFS
• HFS+ - Netduma_JackApr 24, 2019NetDuma Partner
schumaku - my bad! Apologies, missed your post when catching up on the thread.
• FAT16
• FAT32
• NTFS
• Ext2
• Ext3
• Ext4
• HFS
• HFS+I am not sure to understand what brings your initial comment about exFat... It is particularly misleading.
On my side, I should have checked that exFat was in the list. So let's focus on the list provided by Netgear and for this thread Ext4
Hey don't worry, I was more in a kiddding mood!
