Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
schumaku
Apr 23, 2019Guru - Experienced User
Pixys wrote:
My problem is a pure software issue: the lack of support of ext4 is probably due to a missing option in the kernel settings. ... I checked the specs before I bought it, you can have a look as well.
Nothing wrong with your complaint ref. the broken ext4 support as I said before. Christian_R please take care of this issue on all XRnnn routers - ext4 is supported, so it has to be workable.
Pixys wrote:
About the HybridVPN functionality, it is just a joke that it supports only a couple of VPN providers.
Sorry, that's nonense. HybridVPN allows to import any provider OpenVPN config with the inline certificates in the HybridVPN Advanced section. FMI http://support.netduma.com/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
Pixys
Apr 23, 2019Guide
I won't debate about the HybridVPN functionality, this is not something I bought when I chose this router (the functionality did not exist at that time).
That being said I will see again if NordVPN provides config with the inline certificates
- schumakuApr 23, 2019Guru - Experienced UserThey do - just download you account config...
- PixysApr 23, 2019GuideGood to know, thank you
- Netduma_JackApr 24, 2019NetDuma Partner
Hi Pixys - in case you're not aware, Hybrid VPN is compatible with any Open VPN provider, you just need to select the advanced option when setting it up and you then input the Config File. Full instructions here: http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
- schumakuApr 24, 2019Guru - Experienced User
Yeah Netduma_Jack ... as I wrote some posts above already 8-)
- PixysApr 24, 2019Guide
Indeed it works. Nice functionality.
My quick judgement was based on the initiale release that did not support various VPN providers.
schumaku - my bad! Apologies, missed your post when catching up on the thread.
Hey don't worry, I was more in a kiddding mood!
