Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
Pixys
Apr 24, 2019Guide
Good to know, thank you
Netduma_Jack
Apr 24, 2019NetDuma Partner
Hi Pixys - in case you're not aware, Hybrid VPN is compatible with any Open VPN provider, you just need to select the advanced option when setting it up and you then input the Config File. Full instructions here: http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
- schumakuApr 24, 2019Guru - Experienced User
Yeah Netduma_Jack ... as I wrote some posts above already 8-)
- PixysApr 24, 2019Guide
Indeed it works. Nice functionality.
My quick judgement was based on the initiale release that did not support various VPN providers.
- Netduma_JackApr 24, 2019NetDuma Partner
schumaku - my bad! Apologies, missed your post when catching up on the thread.
Hey don't worry, I was more in a kiddding mood!
