Pixys
Jan 16, 2019Guide
[XR500] External USB 3.0 HDD formated in ext4 does not show up in ReadyShare storage
Hello,
My external HDD (Toshiba) formated in EXT4 does not show up in ReadyShare storage. It works when it is formated in NTFS.
According to the user manual p. 121, here: https://www.download...
Netduma_Jack
Apr 24, 2019NetDuma Partner
Hi Pixys - in case you're not aware, Hybrid VPN is compatible with any Open VPN provider, you just need to select the advanced option when setting it up and you then input the Config File. Full instructions here: http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
schumaku
Apr 24, 2019Guru - Experienced User
Yeah Netduma_Jack ... as I wrote some posts above already 8-)
- Netduma_JackApr 24, 2019NetDuma Partner
schumaku - my bad! Apologies, missed your post when catching up on the thread.
- schumakuApr 24, 2019Guru - Experienced User
Hey don't worry, I was more in a kiddding mood!
