Xolhid
Mar 23, 2018Apprentice
XR500 Factory Reset Itself!!!
I woke up this morning with no wifi and no internet to my wired devices. At first I thought my girlfriend didn't pay the internet bill again. I logged into the router to check some things out. Low an...
Netduma-Fraser
Mar 23, 2018NetDuma Partner
Hi Xolhid, the router would have auto upgraded you to the latest version. I imagine that is what caused the factory reset though that shouldn't have happened. Can you continue to monitor the router to see if it factory resets again or if it was just that one off? I'll also look into factory reset after updating automatically.
- XolhidMar 23, 2018Apprentice
It won't be hard to keep an eye on it as the internet is unavailable until the setup is complete. It will be obvious if it happens again. I didn't think I needed to use the backup settings feature, but now I guess I have to.
- ThrelnosMar 26, 2018Tutor
Yeah I'm having the same issue as well it's really annoying and I don't understand what the issue is. This was working just fine for the past week and a half since I got it. I also tried to test something out an a simple reboot and that would trigger this problem as well.
- Netduma-FraserMar 26, 2018NetDuma PartnerHi Threlnos, make sure you're upgraded to the latest version then do a factory reset and let us know if it happens again and if you're able to reproduce it.
