yootzee
Mar 22, 2019Aspirant
XR500 Factory resets itself in the middle of the day, Why?
Continuting my XR500 lovefest (by love, I mean it's making sex to me)...
My XR500 does a factory rest of itself, for not apparent reason, at approximatly 0700pm this evening. No power outage, conn...
Netduma-Fraser
Mar 23, 2019NetDuma Partner
You can do a backup/restore, there is nothing wrong with doing this. However, I would not recommend taking a backup from an old firmware and applying it to a newer firmware. Think of it as firmware specific and it's fine to do so.
I doubt the update would have changed settings. Are you accessing the interface the same way from the same device every time? Did the logs indicate that the router had done a reboot/reset?
