yootzee
Mar 22, 2019Aspirant
XR500 Factory resets itself in the middle of the day, Why?
Continuting my XR500 lovefest (by love, I mean it's making sex to me)...
My XR500 does a factory rest of itself, for not apparent reason, at approximatly 0700pm this evening. No power outage, conn...
yootzee
Mar 23, 2019Aspirant
Fraser,
Thanks for clearing up the backup/restore question. You can believe the firmware update outcome or not (it appears not). So many folks can't believe it becuase it doesn't happen to them. I was here, I saw the settings, like the "Router MAC Address" setting change from "use default" to "use computer MAC address", which broke my passthrough with Uverse. and MAC reservations go bye bye, which broke printing. However, kept things like WiFi settings.
Stuff happens with firware updates, I get it, so it is what it is and this was a month or so ago so I'd swallowed it and moved on. I'll do another firmware update, only when a security issue is resolved, and be ready for a problem that hopefully won't come.
My motivation behind this post is that, unrelated to any changes, the router did a full factory out of the box reset, in the middle of the day removing everything.
Yes, I'm accessing the interface through the same browser (granted, Firefox updates occasionally) on the same hardwared system. No one was accessing the admin interface during the reset and I'm the only one who uses the admin interface.
Unfortunatly, the logs have truncated, assuming I'm looking in the right spot (system information -> Logs and/or settings -> monitoring -> logs). But, I just did a export and would be happy to let you take a look if you think it would help.
Netduma-Fraser
Mar 23, 2019NetDuma Partner
This is certainly really strange. Do you have the router plugged into a power extender/strip rather than directly into a wall outlet? If so can you switch it over to the wall please. Unforeseen issues can occur if it's not receiving the correct power.
- yootzeeMar 23, 2019Aspirant
Power can definetly cause problems. I have the XR500, my Uverse router and my dekstop plugged directly into a known good UPS (APC 1500 Pro).
- Netduma-FraserMar 23, 2019NetDuma PartnerDo you have the ability to plug it into an outlet rather than the APC?
I can. However, I'd rather not. I live on the coast (Florida) in an area that does not have the cleanest of power. We are prone to brown outs, and wicked lightening storms. I've learned the hard way that any electronics that I value don't go directly into a power outlet. I do have another known good UPS that I'll plug it into.
