Laryke
Oct 29, 2021Apprentice
XR500 fiber
What will be the best settings for a fiber connection. Also when I do a test on dslreports, I got C grade on bufferbloat and upload speed is always 940+ even I have qos set to “Always” and upload to ...
Netduma-Fraser
Oct 29, 2021NetDuma Partner
Bufferbloat only occurs when the connection is saturated and at your speeds that is quite hard to do. I would recommend you try different percentages and find what feels best to you when gaming - every connection is different so it's hard to give a definitive value but we usually recommend 70% as a starting point
Laryke
But feels like for upload even if I put Qos at 25% and always, I still get full speed
- Netduma-FraserOct 29, 2021NetDuma PartnerWhat is the modem model the XR is connected to? Are you using PPPoE, VLAN or IPv6 on the XR?
- LarykeOct 29, 2021ApprenticeThe router is connected to the fiber using vlan 201
- Netduma-FraserOct 29, 2021NetDuma PartnerCould be VLAN preventing that working, can you try the beta version here and see if upload adheres to your limit please?
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196
