onemarbledotcom
Aug 02, 2020Initiate
XR500 Firmware 2.3.2.56 is junk and needs to be fixed
This is the third time I have tried upgrading from 2.3.2.32 to 2.3.2.56 on my XR500. Previous 2 times were several months ago and when .56 was initially released. My Galaxy Note 9 won't even recon...
Netduma-Fraser
Aug 03, 2020NetDuma Partner
Sorry to hear you're having the issues. The next version of the software that will include fixes and lots of new features is currently in beta. If you sign up here and let me know then I can try to boost you up the waiting list so you have the chance to try it sooner. Do keep in mind it will have some bugs initially. http://www.netgearinnovation.com/dumaos-beta/index.html
Another suggestion would be to reinstall .56 using the TFTP method, thereby bypassing any bugs during boot and then do a factory reset. That may prove to be more stable until you get on the beta/it is released.
- SturmButcherAug 05, 2020Aspirant
Same here, the router dont work as expected, the coverage is poor and almost useless, I have to reboot it daily to make it work, I signed to beta and still dont get any answer...
- Netduma-FraserAug 05, 2020NetDuma PartnerWhat issues are you having specifically? If you're using Smart Connect disable that and connect to 2.4/5GHz manually. Also position your antennae so they are in optimal positions and don't have the router surrounded/resting on metal as that will kill the signal. Wireless devices e.g headphones within a short distance could also affect this.
- SturmButcherAug 05, 2020AspirantOf course it's enabled, I didn't buy something to have it disable, that's why I am waiting the beta or the launch of the product because it's taking too long...
